AD7715 - nekaj softvera
MarE
Prispevkov: 177
PrispevekObjavljeno: Sre Jan 05, 2005 2:07 pm    Naslov sporočila: AD7715 - nekaj softvera Odgovori s citatom
Tule objavljam nekaj kosov kode za (generično) komunikacijo z AD7715. Sicer se da stvari rešit tudi z bolj prefinjenimi prijemi (npr. z uporabo hardverskega SPI, ki ga ima veliko mikrokontrolerjev), vendar je tole bolj splošna rešitev.
1. najprej definiramo bite za komunikacijo:
sbit AD_DRDY= P1^0;
sbit AD_DATA= P1^1;
sbit AD_CLK = P1^2;
2. navedemo prototipe funkcij:
 * Prototypes of AD7715 functions
void ad_byte_out(uchar byte_out);
void ad_init_bus();
uchar ad_byte_in(void);
void ad_setup(uchar conf, uchar gain);
3. Definiramo nekaj konstant za lažje razumevanje:
// Communication register
#define AD_RS_COMM               0
#define AD_RS_SETUP               0x10
#define AD_RS_TEST               0x20
#define AD_RS_DATA               0x30
#define AD_READ                  0x08
#define AD_WRITE               0
#define AD_STBY                  0x04
#define AD_GAIN1                0
#define AD_GAIN2               1
#define AD_GAIN32               2
#define AD_GAIN128               3
// Setup register
#define AD_MODE_NORMAL            0
#define AD_MODE_SELFCALIBRATION      0x40
#define AD_MODE_ZEROSCALE         0x80
#define AD_MODE_FULLSCALE         0xc0
#define AD_CLKHI               0x20
#define AD_CLKLO               0
#define AD_FILTER1               0
#define AD_FILTER2               0x08
#define AD_FILTER3               0x10
#define AD_FILTER4               0x18
#define AD_BIPOLAR               0
#define AD_UNIPOLAR               0x04
#define AD_BUFFERED               0x02
#define AD_UNBUFFERED            0
#define AD_FSYNC               1
#define AD_NOFSYNC               0
4. Pa še same rutine:
 * Initialize serial bus lines for AD7715.
void ad_init_bus() {
  uchar i;
  AD_DRDY = 1;
  AD_DATA = 0;
  AD_CLK = 1;
  AD_DATA = 1;
  for (i=0; i<32; i++) {  // RESET DEVICE
      AD_CLK = 0;
        AD_CLK = 1;
  delay_ms(100);
 * Send one byte on the AD7715 bus.
    uchar bit_count=8;
    while(bit_count)
     AD_CLK = 0;
     AD_DATA = byte_out & 0x80;
     AD_CLK = 1;
     byte_out <<= 1;
      bit_count--;
   while (AD_DRDY); // wait DRDY
 * Reads one byte in from the AD7715
    uchar bit_count=8;
   bit sampled_data;
   uchar byte_in;
   AD_DATA = 1;
    while(bit_count)
        AD_CLK = 0;
        sampled_data=AD_DATA;             //sample data from AD7715
      AD_CLK = 1;
        if (sampled_data) byte_in |= 0x01;
        else byte_in&=~0x01;
      if (bit_count!=1)                   //last bit is already in position
         byte_in <<= 1;               //shift next bit and store
        bit_count--;
  return byte_in;
 * Setup AD7715
void ad_setup(uchar conf, uchar gain) {
  ad_byte_out(AD_RS_SETUP + AD_WRITE + gain); // write to configuration register
  ad_byte_out(conf);
 * Get unipolar voltage from AD7715
unsigned int ad_get_unipolar(uchar gain) {
uchar adhi,adlo;
unsigned int rez;
  ad_byte_out(AD_RS_DATA + AD_READ + gain);
  adhi = ad_byte_in();
  adlo = ad_byte_in();
  rez = adhi;
  rez<<=8;
  rez |= adlo;
  return rez;
 * Get bipolar voltage from AD7715
int ad_get_bipolar(uchar gain) {
uchar adhi,adlo;
int rez;
  rez = adhi;
  rez<<=8;
  rez |= adlo;
  return rez;
Tipična uporaba bi zgledala tako:
Tako se zadevo inicializira:
  ad_init_bus();
  ad_setup(AD_MODE_SELFCALIBRATION + AD_CLKHI + AD_FILTER1 + AD_UNIPOLAR , AD_GAIN1);
  while (AD_DRDY); // wait for AD7715 selfaclibration complete
Takole pa odčita:
      unsigned int volt[16];
      for  (j=0; j<16; j++)
        volt[j] = ad_get_unipolar(AD_GAIN1);
V zadnjem primeru seveda nisem navedel inicializacije portov mikrokontrolerja. Pini morajo imeti naslednje funkcije:
AD_CLK - OUT (ali open drain+pullup)
AD_DATA - I/O oz. kvazi bidirectional (*)
AD_DRDY - IN
(*) - če mikrokontroler tega ne omogoča (hm, ne vem, če tak obstaja), potem se lahko loči pine na AD_DATAIN in AD_DATAOUT in temu ustrezno popravi rutini za pisanje in branje.
Upam, da bo komu koristilo pri ne-odkrivanju tople vode.
