LCD: cmc216n02 - 16 znakov, 2 vrstici
Gregor
Pridružen/-a: Pon Dec 2004 10:39
Prispevkov: 11
PrispevekObjavljeno: Pon Dec 20, 2004 10:48 am    Naslov sporočila: LCD: cmc216n02 - 16 znakov, 2 vrstici Odgovori s citatom
vse sorte sem ze probal, pa mi ne uspe napisat programa, da bi nekaj izpisal na lcd (cmc216n02 - 16 znakov, 2 vrstici) z atm89s2051.
A mi lahko kdo pomaga?
plis, napisi prog.bas
tile mi ne delajo.... ali bi morali?!?
poskus 1:
Dim Lucka As Bit 'deklaracija spremenljivke Lucka
Lucka = 0
Lucka = 0 'prizgi
P3.7 = Lucka
Wait 2
Lucka = 1 'ugasni
P3.7 = Lucka
Waitms 500
Config Lcdpin = Pin , Db4 = P3.1 , Db5 = P3.2 , Db6 = P3.3 , Db7 = P3.4 , E = P3.5 , Rs = P3.0
Rem with the config lcdpin statement you can override the compiler settings
' Bascom8051 & pg303
'LCD: cmc216n02 - 16 znakov, 2 vrstici
Config Lcd = 16 * 2 'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
'When you dont include this option 16 * 2 is assumed
'16 * 1a is intended for 16 character displays with split addresses over 2 lines
'$LCD = address will turn LCD into 8-bit databus mode
' use this with uP with external RAM and/or ROM
' because it aint need the port pins !
Cls 'clear the LCD display
Lcd "Hello world." 'display this at the top line
poskus 2:
'Dim Lucka As Bit 'deklaracija spremenljivke Lucka
'Lucka = 0
Config Lcdpin = Pin , Db4 = P1.4 , Db5 = P1.5 , Db6 = P1.6 , Db7 = P1.7 , E = P3.7 , Rs = P1.0
'Config Lcd = 16 * 2 'configure lcd screen
pini 1-14
vss (-) ---- r=22k ---- vdd (+) ---- vee( na r=22k) ---- rs ---- r/w ----- ena ----- d4 ---- d5 ----- d6 ---- d7
Gregor
MarE
Prispevkov: 177
PrispevekObjavljeno: Pon Dec 20, 2004 11:28 am    Naslov sporočila: Odgovori s citatom
Precej komentarjev... ampak kje pa inicializiraš LCD? Ali je to kar "avtomatsko" ?
Poglej, če se lahko kaj naučiš iz tegale sourca (sicer je C, ampak vseeno):
#include <reg51.h>
#define    LCD_CLS   0x01   /* koda za brisanje ekrana   */
#define    LCD_HOME   0X02   /* zacetek          */
#define    LCD_ON      0x0e   /* vklop prikaza      */
#define  LCD_CUROFF   0x0c   /* izklop kurzorja      */
#define    LCD_4BIT   0x2c   /* nastavitev nacina delovanja   */
#define  LCDport    P1
sbit RS      = LCDport^4;      /* RS signal LCD */
sbit EN      = LCDport^5;      /* enable LCD */
void delay(unsigned char count)      /* zakasnitev (count * 10 us) */
{               /* ni tocna zakasnitev */
  unsigned char i;
  for (i=0;i<count;i++);
void delay_ms(unsigned int time)   /* zakasnitev v ms */
  unsigned int j;
  for (j=0;j<time;j++)
    delay(105);
void LCD_write (unsigned char znak)
  LCDport &= 0xf0;
  LCDport |= znak >> 4;
  EN = 1;
  delay(1);
  EN = 0;
  LCDport &= 0xf0;
  LCDport |= (znak & 0x0f);
  EN = 1;
  delay(1);
  EN = 0;
void LCD_wrcom (unsigned char znak)
  RS = 0;
  LCD_write (znak);
void LCD_wrdta (unsigned char znak)
  RS = 1;
  LCD_write (znak);
void LCD_init()
  delay_ms (15);
  LCDport = 0xf3;          // 3 x 8-bit mode, 1 x 4-bit mode
  RS = 0;
  delay(1);
  EN = 0;
  delay_ms (6);
  EN = 1;
  delay(1);
  EN = 0;
  delay_ms (1);
  EN = 1;
  delay (1);
  EN = 0;
  delay_ms (1);
  EN = 1;
  LCDport &= 0xfe;
  EN = 0;
  LCD_wrcom(LCD_4BIT);
//  LCD_on();
//  LCD_cls();
//  LCD_home();
//  LCD_dld(SLOfont);
//  LCD_home();
Gregor
Prispevkov: 11
PrispevekObjavljeno: Pon Dec 20, 2004 11:48 am    Naslov sporočila: LCD: cmc216n02 - 16 znakov, 2 vrstici (2nd) Odgovori s citatom
najlepša hvala:)
kako to vpisem v IC ali kako preizkusim program?
Gregor
MarE
Prispevkov: 177
PrispevekObjavljeno: Pon Dec 20, 2004 1:08 pm    Naslov sporočila: Odgovori s citatom
??? Rabiš prevajalnik, linker in programator, ki bo to spravil v čipuzelj.
Prispevkov: 2074
PrispevekObjavljeno: Pon Dec 20, 2004 2:31 pm    Naslov sporočila: Odgovori s citatom
Gregor,
kaj ti pa napiše na LCD-ju? Ali sploh kaj napiše?
Gregor
Prispevkov: 11
PrispevekObjavljeno: Pon Dec 20, 2004 5:04 pm    Naslov sporočila: IMA KDO IZKUŠNJE? LCD:cmc216n02 - 16 znakov, 2 vrstici (3rd) Odgovori s citatom
oh, hvala vam za pomoč. sploh nisem zares pričakoval pomoči - izgleda, da je vredno poizkusit:)))
2-vrstični LCD. ko vse prklopim, je prva vrstica zapolnjena s polnimi znaki.
2. vrsta pa je prazna.
zal mi je, ko imam 4 take displaye,
mam bascom
pg302,
a ne dela.
no, vsaj vem, da je tezava le v programu (mislim da ne LCD, k so novi)
ko bi vsaj nekdo poslal preizkušen *.bas za ta LCD.
algoritem, naj bi bil temu podoben.
NIKAKOR ne morem pogruntat v čem je finta - kje je napaka ...
Config Lcdpin = Pin , Db4 = P1.4 , Db5 = P1.5 , Db6 = P1.6 , Db7 = P1.7 E = P3.7 , Rs = P1.0 ' določimo pine
' LCD: cmc216n02 - 16 znakov, 2 vrstici
'Config Lcd = 16 * 2 'tukaj konfiguriramo tip LCD-ja
'over 2 lines
Cls 'izbriši LCD displej
Lcd "Hello world." 'izpisi tekst
Gregor
strobos
Pridružen/-a: Tor Jan 2004 17:26
Prispevkov: 32
Kraj: LJ
PrispevekObjavljeno: Pon Dec 20, 2004 5:31 pm    Naslov sporočila: Odgovori s citatom
Pozdrav,
za temle ukazom:
moraš dati eno zakasnitev npr.:
wait 1
drugače ti to takoj zbriše.
strobos
Prispevkov: 32
Kraj: LJ
PrispevekObjavljeno: Pon Dec 20, 2004 5:35 pm    Naslov sporočila: Odgovori s citatom
Aja pa config lcdpin in config lcd daj iz zanke do loop-daj pred zanko.
Probaj in poročaj kako je.
Silvo
Prispevkov: 234
PrispevekObjavljeno: Pon Dec 20, 2004 8:09 pm    Naslov sporočila: Odgovori s citatom
Kot je napisal mare LCD ni inicaliziran. (tipični prikaz) Torej preden se ne "postavi" ne bo sprejemal nič.
SimonS
Prispevkov: 181
Kraj: Kobarid
PrispevekObjavljeno: Pon Dec 20, 2004 8:24 pm    Naslov sporočila: Odgovori s citatom
Ziv
Jaz dodam se ukaza
Cursor Off
Display On
Sicer pa mislim, da to ni glavni vzrok. Lahko predvidevam, da uporabljas 2051 ali 4051 in kot vidim uporabljas tudi pin p1.0, ki pa je na teh uC-jih brez pull up upora in zadeva ne more funkcionirati, ce pa slucajno dela pa ne dela pravilno! Dodaj se en pull up upor 10 proti VCC in zadeva bi skoraj morala delati
Skupaj smo mocnejsi
LP Simon
strobos
Prispevkov: 32
Kraj: LJ
PrispevekObjavljeno: Pon Dec 20, 2004 10:08 pm    Naslov sporočila: Odgovori s citatom
Tisti upor ni 10ohm ampak 10kohm ali pa 4,7kohm ali pa nekaj takega probaj.
SimonS
Prispevkov: 181
Kraj: Kobarid
PrispevekObjavljeno: Tor Dec 21, 2004 5:51 pm    Naslov sporočila: Odgovori s citatom
Wops Embarassed se opravicujem 10K sem imel v mislih ja. Vsekakor je tudi 4k7 prav tako dober. Mogoce celo boljsi.... Vsakem primeru vrednost ni kriticna.
Skupaj smo mocnejsi
LP Simon
Prispevkov: 2074
PrispevekObjavljeno: Sre Dec 22, 2004 7:55 am    Naslov sporočila: Odgovori s citatom
'over 2 lines
1. Do ukaz prestavi pred ukaz CLS
2. vidim, da imas ukaz Config LCD REM-an - pomeni, da je to komentar. Izbriši znak ' pred tem ukazom.
3. za ukazom Lcd "hello....." dodaj ukaz wait 1, drugače se ne bo nič videlo.
Potem pa poročaj, če si bil uspešen.
Gregor
Prispevkov: 11
PrispevekObjavljeno: Ned Dec 26, 2004 6:21 pm    Naslov sporočila: display 16x2 Odgovori s citatom
zal ne dela. se ne vdam:)...
a vam drugace dela?
PS:
na ELEKTRO-N sem tudi zasledil en clanek, da je nekdo imel tezave in prav z enakim LCD-jem in AT89c2051.
Gregor
PrispevekObjavljeno: Ned Dec 26, 2004 6:36 pm    Naslov sporočila: LCD Odgovori s citatom
Gregor!
Daj zraven svoj program in opiši kako si priklopil LCD,drugače je težko pomagati.
Stran 1 od 3
