ne znam
ata
Pridružen/-a: Pon Apr 2004 9:26
Prispevkov: 104
PrispevekObjavljeno: Sob Nov 22, 2014 12:58 pm    Naslov sporočila: ne znam Odgovori s citatom
pri izvajanju programa se zmeraj začne in zaključi v tem delu programa-prosim za pomoč:
If Ta > 8 Then
If T > 33 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
drugega stolpca ne upošteva :
If Ta <8> 36 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
to je celotni program:
$large
Declare Sub Read1820
Declare Sub Temperature
Declare Sub Srno1
Declare Sub Srno2
Dim T2 As Integer , T4 As Integer
Dim Bd(9) As Byte
Dim I As Integer ,
Dim T As Integer , T1 As Integer , Voda As Byte , Zrak As Byte , Ta As Byte
Dim Clock As Byte , Clock1 As Byte
Dim Sekunde As Byte , Minute As Byte , Minute1 As Byte , Ure As Byte , Tmp As Byte
Dim Ar(8) As Byte
Config Timer0 = Timer , Gate = Internal , Mode = 2
On Timer0 Timer_0_int
Load Timer0 , 250
Priority Set Timer0
Enable Timer0
Config Lcd = 16 * 2
Config 1wire = P3.0
Cursor Off Noblink
Clock = 0
Clock1 = 0
Sekunde = 0
Minute = 0
Ure = 0
Start Timer0
If Sekunde > 59 Then
Incr Minute
Sekunde = 0
Srno1
Temperature
Locate 1 , 1 : Lcd "dvizni vod "
Voda = T4
Lcd T
Lcd Chr(46)
Lcd T1
T = Voda
If Ta > 8 Then
If T > 33 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
If Ta <8> 36 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
Srno2
Temperature
Locate 2 , 1 : Lcd "zunanja t "
Zrak = T4
Lcd Ta
Lcd Chr(46)
Lcd T1
Rem ////////////////////////////////////////////////////////////////////////////
' read address 1
Sub Srno1
For I = 0 To 7
Ar(i) = Lookup(i , Dta1)
Next
End Sub
' read address 2
Sub Srno2 'branje adrese 1
For I = 0 To 7
Ar(i) = Lookup(i , Dta2)
Next
End Sub
Dta1:
Data 16 , 148 , 162 , 208 , 1 , 8 , 0 , 250
Dta2:
Data 16 , 73 , 76 , 180 , 1 , 8 , 0 , 146
Sub Temperature 'merjenje temperature
1wreset
1wwrite &H55
1wwrite Ar(0) , 8 '1Wire ukaz
1wwrite &H44
Waitms 255
Waitms 255
Waitms 250
Read1820 'read 9 bytes
End Sub
Sub Read1820
Stop Timer0 'bere senzor 'T za 0.1 C
1wreset 'reset
1wwrite &H55 '1Wire ukaz
1wwrite Ar(0) , 8
1wwrite &HBE
Bd(1) = 1wread(9)
1wreset
Start Timer0
Tmp = Bd(1) And 1 '0.1C natancnost
If Tmp = 1 Then
Decr Bd(1)
T = Makeint(bd(1) , Bd(2))
T4 = T / 2 'T4 lahko uporabimo, ce zelimo temp. kot celo stevilo
T = T * 50 : T = T - 25 : T1 = Bd(8) - Bd(7) : T1 = T1 * 100
T1 = T1 / Bd(8) : T = T + T1 : T = T / 10
T1 = T
T = T / 10
T2 = T * 10
T1 = T1 - T2
T1 = Abs(t1)
End Sub
Timer_0_int:
Incr Clock
If Clock > 99 Then
Clock = 0
Incr Clock1
If Clock1 > 39 Then
Clock1 = 0
Incr Sekunde
ata
Prispevkov: 104
PrispevekObjavljeno: Sob Nov 22, 2014 2:41 pm    Naslov sporočila: Odgovori s citatom
If Ta <8> 36 Then
tu je napaka je manj kot 8 brez 36 -pozabil sem kako se pripne original program
Set Minute
vmes manjka
if t>36 then
ali moram uporabiti podprograme (gosub)
Prispevkov: 2065
PrispevekObjavljeno: Sob Nov 22, 2014 11:14 pm    Naslov sporočila: Odgovori s citatom
Ata,
sem tvoj program dal v Bascom se vidi, da ti manjka nekaj dvopilčij za oznako subrutin.
Recimo v vrstici 64 in 65 je tole:
Srno1
Temperature
brez npr gosub Srno1 je že "sumljivo".
CPU ni definiran na začetku programa.
Set Minute ukaz je nenavaden, saj je spremenljivka Minute byte. Set ukaz deluje na Bitnih spremenljivki
Ta ukaz se mi zdi nenavaden: If Ta <8> 36 Then
Moral bi napisati: If Ta <8 or if Ta> 36 Then
Predlagam, da program simuliraš in si ogledaš, kako program deluje/skače iz vrsice v vrstico,
igo
Prispevkov: 85
Kraj: Krško
PrispevekObjavljeno: Pet Nov 28, 2014 1:40 pm    Naslov sporočila: Odgovori s citatom
Vmesnik za vpisovanje besedila si nekatera zaporedja znakov razlaga precej po svoje, tudi pri citiranju (Quote) ali pripetju kode (Code).
Če iz : in ) nastane smeško Smile , je še najmanjši problem. Včasih del besedila kar izgine, ali povsem spremeni obliko.
In potem tudi pravilen program deluje čudno.
Najbolje, da cel program priložiš v .txt priponki.
Srno1
Temperature
Voda = T4
Lcd T
Lcd Chr(46)
Lcd T1
T = Voda
If Ta > 8 Then ' Then what ??? Torej, kaj potem??? Pred End If manjka vsaj ena vrstica.
If T > 33 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
If Ta <8> 36 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 15 Then
P3.4 = 1
Reset Minute
Srno2
Temperature
Zrak = T4
Lcd Ta
Lcd Chr(46)
Lcd T1
Kaj naredi ukaz "set Minute" ali "reset Minute" z 8-bitno (byte) spremenljivko "Minute"?
In kako se rezultat primerja z 8, 15 in 36?
ata
Prispevkov: 104
PrispevekObjavljeno: Sob Nov 29, 2014 10:48 am    Naslov sporočila: Odgovori s citatom
ta del se izvaja če je pa tz manjša ali večja pa ne-program zmeraj uporabi prvi stolpec
If Tz > 11 Then
If Tn > 34 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 6 Then
P3.4 = 1
Reset Minute
če je tz manjša tn pa večja pa nr
$large
Declare Sub Srno1
Declare Sub Srno2
Dim Bd(9) As Byte
Dim I As Integer ,
Dim T As Integer , T1 As Integer , Tz As Byte , Tn As Byte
Dim Ar(8) As Byte
Load Timer0 , 250
Priority Set Timer0
Enable Timer0
Config Lcd = 16 * 2
Config 1wire = P3.0
Cursor Off Noblink
Clock = 0
Clock1 = 0
Sekunde = 0
Minute = 0
Ure = 0
Start Timer0
Incr Minute
Sekunde = 0
Srno1
Temperature
Tn = T4
Lcd T
Lcd Chr(46)
Lcd T1
Srno2
Temperature
Tz = T4
Lcd T
Lcd Chr(46)
Lcd T1
If Tz > 11 Then
If Tn > 34 Then
P3.4 = 0
Minute = 0
Set Minute
If Minute > 6 Then
P3.4 = 1
Reset Minute
'spodnji stolpec je tak kot zgornji samo tz in tn sta drugačni
If Tz <7> 37 Then
P3.4 = 0
Minute = 0 napaka
Set Minute
If Minute > 6 Then
P3.4 = 1
Reset Minute
' read address 1
Sub Srno1
For I = 0 To 7
Next
End Sub
' read address 2
For I = 0 To 7
Next
End Sub
Dta1:
Dta2: 'naslov 1 Dallasa
1wreset
1wwrite &H55
1wwrite &H44
Waitms 255
Waitms 255
Waitms 250
End Sub
Sub Read1820
1wreset 'reset
1wwrite Ar(0) , 8
1wwrite &HBE
Bd(1) = 1wread(9)
1wreset
Start Timer0
If Tmp = 1 Then
Decr Bd(1)
T1 = T
T = T / 10
T2 = T * 10
T1 = T1 - T2
T1 = Abs(t1)
End Sub
Timer_0_int:
Incr Clock
If Clock > 99 Then
Clock = 0
Incr Clock1
If Clock1 > 39 Then
Clock1 = 0
Incr Sekunde
igo
Prispevkov: 85
Kraj: Krško
PrispevekObjavljeno: Sob Nov 29, 2014 3:39 pm    Naslov sporočila: Odgovori s citatom
 If Tz > 11 Then
' Še vedno trdim, da tukaj nekaj manjka !!!
Ne more biti kar If /pogoj/ Then /-prazno-/ End If.
In kako je z VELIKIMI/malimi črkami?
 For I = 0 To 7
Next
Je vseeno, če je "I" ali "i" ?
Program pripni na forum kot priponko - pod oknom za vnos besedila je gumbek [Add an Attachment ]. Če forum ne dovoli pripeti .bas končnice, shrani končnico v .txt (odpri original datoteko z Beležnico, jo shrani na Namizje in nato pripni sem).
ata
Prispevkov: 104
PrispevekObjavljeno: Ned Nov 30, 2014 7:18 pm    Naslov sporočila: Odgovori s citatom
na noben način ne morem pripeti pravilnega programa
igo
Prispevkov: 85
Kraj: Krško
PrispevekObjavljeno: Pon Dec 01, 2014 1:17 pm    Naslov sporočila: Odgovori s citatom
Namizje
DesniMisGumb
Nov dokument z besedilom
- ga odpreš
- odpreš še datoteko s tvojim programom
- označiš vse (Ctrl + a)
- kopiraš (Ctrl + c)
- vstaviš v Beležnico (Ctrl + v)
- shraniš (Ctrl + c)
- nato odpreš odgovor na to temo
- pod oknom za vnos besedila klikni gumb [Add an Attachment] za dodajanje priponk
- pobrskaš [Browse] do priponke in jo dodaš
- v okno z besedilom dodaš Smile , ker forum ne dovoli oddajanja sporočila samo s priponko
- oddaš
Brez celega programa je nemogoče najti napako.
PrispevekObjavljeno: Pon Dec 01, 2014 9:14 pm    Naslov sporočila: Odgovori s citatom
Igo je napisal:
ja čisto vseeno je.
Ata,
Kaj naj bi naredil ta ukaz:
If Ta <8> 36 Then
IF Ta<8 or Ta>36 then ' bi mogoče bilo pravilno
Tako dolgega programa ne bo nobeden analiziral. Sam tako dolge programe testiram po delih, ali jih pišem kot include fajle.
Prispevkov: 2065
PrispevekObjavljeno: Tor Dec 02, 2014 8:27 am    Naslov sporočila: Odgovori s citatom
Ata,
na moj mail mi pošlji program, da ga bom jaz prilepil na forum.
Piši na stik@svet-el.si
PrispevekObjavljeno: Tor Dec 02, 2014 10:24 am    Naslov sporočila: Odgovori s citatom
Če v programu ni definiran procesor, (je definiran v Bascom-u), dodaj še podatke o procesorju.
ata
Prispevkov: 104
PrispevekObjavljeno: Tor Dec 02, 2014 4:26 pm    Naslov sporočila: Odgovori s citatom
Jure hvala-14dni nimam kaj dosti časa-ko bom naredil bom sporočil na forum
