MCP41HV31 digitalni potenciometer
mucek.g
Pridružen/-a: Tor Feb 2014 21:25
Prispevkov: 6
PrispevekObjavljeno: Tor Mar 18, 2014 8:23 pm    Naslov sporočila: MCP41HV31 digitalni potenciometer Odgovori s citatom
Jure je na svojem blogu objavil članek o tem digitalnem potenciometru in navdušil tudi mene ... Spodaj koda za igranje, sam sem uporabil HW SPI, komentirana je tudi koda za SW SPI ...
Me pa zanima (Jure?), ali si poskušal tudi z direktnim vpisom vrednosti v sam register čipa? Sem se nekaj trudil, a brez uspeha. (če zadevo večem/manjšam, brez problema pridem do želene vrednosti, ne gre pa mi direktni vpis).
Lp, g
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1 Spiinit
'Config Spi = Soft , Din = Pinb.5 , Dout = Portc.2 , Clock = Portb.7 , Ss = None
Cs Alias Portb.4
Wlat Alias Portb.3
Shdn Alias Portb.2
Config Cs = Output
Config Wlat = Output
Config Shdn = Output
Cs = 1                                                      'non active state
Wlat = 1
Shdn = 1
Dim Incr_comm As Byte
Dim Decr_comm As Byte
Dim Read_comm As Byte
Dim Write_comm As Byte
'commands
Decr_comm = &B00000111                                      'increment command
Incr_comm = &B00001011                                      'decrement command
Read_comm = &B00001111                                      'read command
Write_comm = &B00000011                                     'write command
Dim Resistance As Byte : Resistance = 0
Dim Wiper As Word
'SPI test
Waitms 100
Spiinit
Waitms 100
'read data from MCP41HV31 to see how the resistance is set
Cs = 0
Spiout Read_comm , 1
Spiin Resistance , 1
Gosub Calculate
Cs = 1
'Set_resistance
Main_resistor:
   Print "Wiper:" ; Wiper ; "   "
   If T1 = 0 Then Gosub Up_sub
   If T2 = 0 Then Gosub Down_sub
   waitms 500
Calculate:
   Wiper = Resistance * 190
   Wiper = Wiper + 280
'subroutines
Up_sub:
   Set Led_close
   Waitms 50
   Cs = 0                                                   'active
   Waitms 100
   Incr Resistance
   Spiout Incr_comm , 1
   Spiout Read_comm , 1                                     'command to read set resistance
   Spiin Resistance , 1                                     'read set resistance
   Gosub Calculate
   Wlat = 0                                                 'set to write to SPI register
   Cs = 1
   Reset Led_close                                          'not active
Down_sub:
   Set Led_open
   Waitms 50
   Cs = 0
   Waitms 100
   Decr Resistance
   Spiout Decr_comm , 1
   Gosub Calculate
   Cs = 1                                                   'not active
   Reset Led_open
Prispevkov: 2058
PrispevekObjavljeno: Sre Mar 19, 2014 9:54 am    Naslov sporočila: Odgovori s citatom
Digitalni POT res lepo dela, Gregatu je manjkala ena subrutina, ki jo najdete v mojem blogu in se imenuje Test_sub.
V tej subrutini pišemo vrednost upornosti v potenciometer.
mucek.g
Prispevkov: 6
PrispevekObjavljeno: Sre Mar 19, 2014 8:03 pm    Naslov sporočila: Odgovori s citatom
Dodatno je bil problem še, da mi pri uporabi HW SPI prejemanje ni delovalo (torej - lahko sem poslal ukaz, nisem pa mogel prejeti odgovora). Ko sem zadevo nastavil na SW SPI, je zadeva zaživela ... Zadeva je sigurno povezana s kupom nastavitev HW SPI, s čimer pa se žal nisem imel časa (in volje) ubadati, ko je zadeva zaživela Smile
Jure, hvala za pomoč!
Lp, g
