Servo motor in PWM
malix
Pridružen/-a: Sre Jan 2004 16:11
Prispevkov: 100
Kraj: Maribor
PrispevekObjavljeno: Pet Feb 10, 2012 2:35 pm    Naslov sporočila: Servo motor in PWM Odgovori s citatom
Po dolgem času sem se spet usedel za Atmele AVR 32 in 8MHZ kristal
Predelal sem modelarski servo motor da se lahko neskončno vrti v levo in v desno stran.
Nikakor mi ne uspe narediti PWM signala, ki je primeren za servo motorje
Vsakih 20 ms mora biti impulz dolg 1.25 ms za levo in 1.75 ms za desno stran vrtenja.
Ali ima kdo kaj podobnega kje v predalu?
www.MaLiX.si
Prispevkov: 2060
PrispevekObjavljeno: Pet Feb 10, 2012 10:04 pm    Naslov sporočila: Odgovori s citatom
servo ukaz v Bascomu je malo neposrečen (beri - ne deluje dobro). Zato ti priporočam uporabo tega programa:
'Program *** Step motor ***
$crystal = 8000000
$regfile = "m8515.dat "
$hwstack = 32
$swstack = 8
$framesize = 32
Dim Servo As Word
Ucsrb.3 = 0                                                 'necessary only if bootloader is used
Ucsrb.4 = 0                                                 'necessary only if bootloader is used
Servo1_pin Alias Portb.0                                    'Servo1 control pin
Servo2_pin Alias Portb.0                                    'Servo2 control pin
'in this example only Servo1 is used buth Servo2 definition is necessary;
'therefore, Servo2 targets the same pin as Servo1, but is never used
Gosub Config_servo
   Servo = 1500
   Gosub Servo1                                             'set Servo1 in the middle position
   Wait 5
   For Servo = 900 To 2100
      Gosub Servo1                                          'turn Servo1 slowly from one...
      Waitms 5                                              '... to the other end position
   Next
   Wait 5
'* Servo Motor Subroutines
Dim Servo_aux As Long
Servo1:
   Gosub Servo12
   Disable Interrupts
   Compare1a = Servo_aux
Servo2:
   Gosub Servo12
   Disable Interrupts
   Compare1b = Servo_aux
Servo12:
   Servo_aux = -1
   Decr Servo
   If Servo < 20000 Then
      Servo_aux = _xtal / 1000
      Servo_aux = Servo_aux * Servo
      Servo_aux = Servo_aux / 8000
   Incr Servo
Config_servo:
   Config Servo1_pin = Output
   Config Servo2_pin = Output
   On Compare1a C1a_sub Nosave
   On Compare1b C1b_sub Nosave
   On Capture1 T1_sub Nosave
   Compare1a = -1
   Compare1b = -1
   Capture1 = _xtal / 400
   Enable Compare1a
   Enable Compare1b
   Enable Capture1
   Config Timer1 = Timer , Prescale = 8 , Clear Timer = 1
   Set Tccr1b.wgm13
C1a_sub:
   Reset Servo1_pin
C1b_sub:
   Reset Servo2_pin
T1_sub:
   Set Servo1_pin
   Set Servo2_pin
