Graficni LCD LGM12864B
ivan
Pridružen/-a: Pon Mar 2004 18:49
Prispevkov: 45
Kraj: Cerkno
PrispevekObjavljeno: Tor Jul 19, 2011 1:35 pm    Naslov sporočila: Graficni LCD LGM12864B Odgovori s citatom
Nikakor mi ne uspe oživiti Grafični LCD LGM12864B, kaj delam narobe ?
Iz primerov sem kopiral program "circle.bas" pa se nič ne zgodi.
po ukazu Config Graphlcd sem naredil še en Print "Config_1" , pa se progam ustavi pri tem ukazu, če pa ta ukaz od označim in prevedem
pa lučka lepo utripa v DO zanki na koncu. Program se uspešno prevede v obeh primerih.
'                          circle.bas
'            draws a circle on a graphic display
$regfile = "m32def.dat"                                     ' specify the used micro
$crystal = 8000000                                          ' used crystal frequency
$baud = 9600                                                ' use baud rate
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
Config Portd.7 = Output
Waitms 100
Reset Portd.7
Waitms 100
Set Portd.7
'some routines to control the display are in the glcdKS108.lib file
$lib "glcdKS108.lib"
Wait 1
Print "Config"                                              ' printing will still work as only the receiver pin is disabled
'First we define that we use a graphic LCD
Config Graphlcd = 128 * 64sed , Dataport = Porta , Controlport = Portc , Ce = 0 , Ce2 = 1 , Cd = 2 , Rd = 3 , Reset = 5 , Enable = 4
Print "Config_1"
'The dataport is th e portname that is connected to the data lines of the LCD
'The controlport is the portname which pins are used to control the lcd
'CE, CD etc. are the pin number of the CONTROLPORT.
' For example CE =2 because it is connected to PORTC.2
'mode 8 gives 240 / 8 = 30 columns , mode=6 gives 240 / 6 = 40 columns
Dim I As Byte
'create a solid circle
  For I = 1 To 20
   Circle(40 , 40) , I , 255
Next
 Circle(20 , 20) , 10 , 255                                 'make circle
 Wait 1
 Circle(20 , 20) , 10 , 0                                   'remove circle
 Wait 1
  Waitms 100
Reset Portd.7
Waitms 100
Set Portd.7
V čem je problem !!
LP ivan
Prispevkov: 2132
PrispevekObjavljeno: Tor Jul 19, 2011 6:36 pm    Naslov sporočila: Odgovori s citatom
Ivan,
ali si preveril povezavo (shemo) za ta displej?
