malix Profesionalec
Pridružen/-a: Sre Jan 2004 16:11 Prispevkov: 100 Kraj: Maribor
Objavljeno: Sob Dec 20, 2008 9:28 pm Naslov sporočila: Težave s serijsko komunikacijo pri PCF8583 |
Uporabljam ATmega32
Kristal 8 MH in 38400 RS232
Sda = Portd.4
Scl = Portd.5
Želim usposobiti PCF8583, a ni sreče.
Ko želim kaj izpisati preko Print dobim samo neke čudne znake.
Ko pa ta program zbrišem in napišem samo print«sss« pa deluje OK
Nekje v programu je nekaj falš, da ne deluje serijska komunikacija.
Uporabil sem program, ki ga lahko najdemo v primerih Bascom AVR-ja
Koda: |
$lib "mcsbyte.lbx" ' use the byte lib since we do not need longs
$crystal = 8000000
$baud = 38400
'declare used subs
Declare Sub Settime(byval S1 As Byte , Byval M1 As Byte , Byval H1 As Byte , Byval D1 As Byte , Byval Month1 As Byte)
Declare Sub Gettime()
'Declare variables
Dim Tm(5) As Byte At &H60
Dim I As Byte , Temp As Byte
'These are pointers to tm() for simple handling.
Dim S As Byte At &H60 Overlay
Dim M As Byte At &H61 Overlay
Dim H As Byte At &H62 Overlay
Dim D As Byte At &H63 Overlay
Dim Month As Byte At &H64 Overlay
'configure the used port pin for I2C
Config I2cdelay = 5 ' default slow mode
Config Sda = Portd.4
Config Scl = Portd.5
' not needed since the pins are in the right state
'I2cinit
Call Settime(56 , 1 , 1 , 29 , 11) 'set time
Print Chr(27) ; "[2J"; 'clear screen
Print "PCF8583 Clock Sample"
Do
Call Gettime
'since the values are stored in BCD format we can use Hex() to display them
Print Chr(27) ; "[2;2f"; ' VT100 emulation set pos to 2,2
Print Hex(h) ; ":" ; Hex(m) ; ":" ; Hex(s) ; " Err:" ; Err
Wait 1
Loop
End
Sub Gettime()
'there are 2 ways to get the time. With low level i2c calls or with a high level call
'first the high level call
Tm(1) = 2 ' point to second register
I2creceive &HA0 , Tm(1) , 1 , 5 ' write the second address and get 5 bytes back
'i2creceive will first write 1 byte from tm(1) which is 2, and then will read 5 bytes and store it onto tm(1)-tm(5)
'and optional with low level calls
' For I = 1 To 5
' Temp = I + 1
' I2cstart
' I2cwbyte &HA0 'write addres of PCF8583
' I2cwbyte Temp 'select register
' I2cstart 'repeated start
' I2cwbyte &HA1 'write address for reading info
' I2crbyte Tm(i) , Nack 'read data
' Next
' I2cstop
End Sub
Sub Settime(s1 As Byte , M1 As Byte , H1 As Byte , D1 As Byte , Month1 As Byte)
'values are stored as BCD values so convert the values first
Tm(1) = Makebcd(s1) 'seconds
Tm(2) = Makebcd(m1) 'minutes
Tm(3) = Makebcd(h1) 'hours
Tm(4) = Makebcd(d1) 'days
Tm(5) = Makebcd(month1) 'months
I2cstart 'generate start
I2cwbyte &HA0 'write address
I2cwbyte 0 'select control register
I2cwbyte 8 'set year and day bit for masking
I2cwbyte &HA0 'write mode
I2cwbyte 2 'select seconds Register
For I = 1 To 5
I2cwbyte Tm(i)
Next 'write seconds
I2cstop
End Sub |
Objavljeno: Ned Dec 21, 2008 9:37 am Naslov sporočila: |
Takoj ko sem pogledal tvoj program, sem opazil nekaj, kar mi ni všeč:
Koda: |
'Declare variables
Spremenljivke si postavil na fiksno lokacijo &H60, ne da bi preveril, ali je ta lokacija prosta.
Po prevajanju poglej, kje so dejansko te spremenljivke, in ugotovil boš, da sta tudi spremenljivki I in Temp na istih mestih, torej se prekrivata s spremenljivkami S in M. In to ni fajn, kaj ne?
Predlagam sledeč način definiranja spremenljivk:
Koda: |
'Declare variables
Dim S As Byte
Dim M As Byte
Dim H As Byte
Dim D As Byte
Dim Month As Byte
Dim Tm(5) As Byte At S Overlay
Na ta način nisi se postavil z overlay na fiksno lokacijo, pa vseeno dosežeš željeno prekrivanje spremenljivk, saj je željeno le to, da se prekrivajo spremenljikve S, M, H, D, in Month z TM(5) _________________ Sliši se paradoksalno, a je vendarle res:
malix Profesionalec
Objavljeno: Ned Dec 21, 2008 10:21 am Naslov sporočila: |
Hvala bom preveril.
Ali mi lahko prilepiš tvoj sample iz Bascoma AVT "clock.bas" - če je kaj posodobljen. |
Objavljeno: Ned Dec 21, 2008 10:32 am Naslov sporočila: Preklicujem |
Preklicujem mojo prejšnjo trditev, da je bila napačna definicija spremenljivk.
A načelno vztrajam, da ni varno postavljati spremenljivke na fiksna mesta, ker ne vemo, kam postavlja spremenljivke Bascom sam, če želimo prekrivanje, potem je dobro, da prekrivamo preko simbolnih imen že definiranih spremenljivk.
Vsekakor po opravljenem prevajanju je dobro pregledati poročilo o prevodu, kjer dobiš lokacije spremenljivk, posebno če uporabljaš prekrivanje.
Moj bascom sample clock.bas je tak kot tvoj.
Treba bo potrebno naprej iskati, kaj je narobe, da ti print ne dela.
Začni s tem, da daš takoj po obveznih definicijah o kristalu, mikroprocesorju in baudni hitrosti
Koda: | $hwstack = 128
$swstack = 64
$framesize = 64
print "Dober dan!"
wait 1 |
Objavljeno: Ned Dec 21, 2008 11:55 am Naslov sporočila: ponujam |
Ponujam v uporabo moja podprograma za uporabo RTC PCF8583
Prednost mojih dveh podprogramov je v tem, da vsebuje tudi letnico, ki si jo zapiše na lokacijo 16 RAM-a, ki je v istem čipu, pa tudi dan v tednu.
Uporaba je tako:
V glavnem programu definiraš spremenljivki
Koda: | Dim Z(1) As Byte
Dim Niz1 As String * 18 |
Ti dve spremenljivki se sicer na prekrivata, toda če uporabim pri spremenljivki Z indeks, ki je večji od ena, naslovim bajt v spremenljivki izza Z(1) to pa je odgovarjajoči bajt spremenljivke Niz1.
Definirati moram še konstanti, ki povesta, kako je čip vezan in ali beremo ali pišemo:
Koda: | Const Wrtc = &HA0 ' i2c rtc A0 na +0V:
Const Rrtc = &HA1
in pa seveda config scl in sca.
Ko želimo v glavnem programu zapisati čas in datum v RTC, informacijo damo v Niz1 v obliki ddmmll hhmm dt to se pravi dan mesec leto ura minuta dan v tedni recimo tako:
Koda: | Niz1 = "251208 1200 Ce"
gosub wrtcsr
Zapisali smo 25. dec 2008 ura 1200 Četrtek
(Šumnikov nisem uporabil, ker informacijo često prenašam ali dobivam preko SMS-ov, kjer šumniki niso na razpolago.)
Kadar želim informacijo od RTC-a pa kličem
Koda: | gosub rrtcsr
print Niz1 |
in informacijo dobim v enakem formatu nazaj.
Koda: | ' ---------------------RTC -------------------------------
' Podprograma za pisanje in branje RTC informacij preko skupnega I2C-vodila
' Vhodno/izhodna informacija je v spremenljivki Niz1 definirani kot:
' Dim Z(1) As Byte
' Dim Niz1 As String * 18
' tako da lahko preko spremenljivke y(x) pridemo do poljubnega bajta
' Format informacije je ddmmll uunn Ne
Wrtcsr: 'Wrtcsr: <------
' Iz spremenljivke Niz1 v formatu "ddmmll uumm Ne" v RTC
Reg14 = I : Push R14
Reg14 = J : Push R14
Reg14 = K : Push R14
I = Z(11) And &H0F ' minute
Shift I , Left , 4
J = Z(12) And &H0F
I = I + J
I2cstart ' Start sequence for I2CBUS
I2cwbyte Wrtc ' point address to write to PCF8583
I2cwbyte 0 ' points to register 0
I2cwbyte 0 ' set control register
I2cwbyte 0 ' set hundreds
I2cwbyte 0 ' set seconds
I2cwbyte I ' set minutes
I = Z(9) And &H0F ' ure
Shift I , Left , 4
J = Z(10) And &H0F
I = I + J
I2cwbyte I ' set hours
I = Z(2) And &H0F ' dan v mesecu
Shift I , Left , 4
J = Z(3) And &H0F
I = I + J
J = Z(6) * 10 'leto
J = J + Z(7)
J = J Mod 4
Shift J , Left , 6
I = I Or J
I2cwbyte I ' dan in leto
For I = 0 To 28 Step 2 ' dan v tednu
J = Lookup(i , Dnevi)
Incr I
K = Lookup(i , Dnevi)
Decr I
If J = Z(14) And K = Z(15) Then
Exit For
End If
Next
I = I / 4
If I = 7 Then I = 6 ' če ni našel dneva!
Shift I , Left , 1
If Z(4) = &H31 Then
Incr I
End If
Shift I , Left , 4
J = Z(5) - &H30
I = I Or J
I2cwbyte I ' dan v tednu in mesec
I2cstop
' leto spravimo v dva polja, ker rtc šteje leta samo od 0 do 3, dodamo
' še en bajt, ki ga spravimo v eeprom rtc-a, da dobimo celo letnico
I = Z(6) - &H30 ' aditivna konstanta leta
I = I * 10
J = Z(7) - &H30
I = I + J
I = I / 4
I2cwbyte 16 ' points to ram
I2cwbyte I ' year / 4 '
I2cstop
Pop r14 : K = Reg14
Pop r14 : J = Reg14
Pop r14 : I = Reg14
Return
Rrtcsr: 'Rrtcsr: <-------------
Push R14
I2cwbyte 2 ' point to register 2
I2cstart ' repeat start sequence for I2CBUS
I2cwbyte Rrtc ' point address to read
I2crbyte I , 8 ' seconds and ignore
I2crbyte I , 8 ' minutes
' V Niz1-u boste dobili rezultat recimo tako:
'Niz1 = "051105 0811 So"
' ' x 1...5....0....5!
' ddmmll uumm da
I = I And &H0F
I = I Or &H30
Z(12) = I
pop r14 : i = reg14
Shift I , Right , 4
I = I And &H0F
I = I Or &H30
Z(11) = I
I2crbyte I , 8 ' hours
I = I And &H0F
I = I Or &H30
Z(10) = I
pop r14 : i = reg14
Shift I , Right , 4
I = I And &H0F
I = I Or &H30
Z(9) = I
I2crbyte I , 8 ' year and day
I = I And &H0F
I = I Or &H30
Z(3) = I
pop r14 : i = reg14
Shift I , Right , 4
I = I And &H03
I = I Or &H30
Z(2) = I
pop r14 : i = reg14
Shift I , Right , 6
Z(7) = I ' kasneje popravimo leta
I2crbyte I , 9 ' week and month
I2cstop
I = I And &H0F
I = I Or &H30
Z(5) = I
pop r14 : i = reg14
Shift I , Right , 4
I = I And &H01
I = I Or &H30
Z(4) = I
pop r14 : i = reg14
Shift I , Right , 5
Shift I , Left , 2 'krat 4
' sledeči dve instrukciji opustimo, če želimo angleško verzijo dnevov tedna
Incr I
Incr I
Z(14) = Lookup(i , Dnevi)
Incr I
Z(15) = Lookup(i , Dnevi)
Z(16) = 0 ' konec niza
' Popravek za leto 4-številčno
I2cstart
I2cwbyte Wrtc
I2cwbyte 16 ' point to ram
I2cstart
I2cwbyte Rrtc
I2crbyte I , 9 ' read year / 4
I2cstop
Shift I , Left , 2 ' krat 4
I = I + Z(7)
I = I / 10
Z(6) = &H30 + I
pop r14 : i = reg14
I = I Mod 10
Z(7) = &H30 + I
Z(8) = &H20 'vstavimo blanko znake
Z(13) = &H20
Dancas = Left(niz1 , 14)
Dancas = Dancas + " "
pop r14 : j = reg14
pop r14 : i = reg14
pop r14
Return
Dnevi:
Data "SuNeMoPoTuToWeSrThCeFrPeSaSo" ' Dan v tednu
' -----------------------------RTC KONEC -------------------------------
malix Profesionalec
Objavljeno: Pon Dec 22, 2008 9:15 pm Naslov sporočila: Re: Preklicujem |
vilko je napisal/a: |
$swstack = 64
$framesize = 64
print "Dober dan!"
wait 1 |
Ko prekopiram tole v Bascom AVR mi napiše sledeče.
Error : 46 Line : 1 Assignment error [$HWSTACK: 112 128: 112] , in File : C:\USERS\...\CLOCK.BAS
Error : 46 Line : 2 Assignment error [$SWSTACK: 112 64: 112] , in File : C:\USERS\...\CLOCK.BAS
Error : 46 Line : 3 Assignment error [$FRAMESIZE: 112 64: 112] , in File : C:\USERS\...\CLOCK.BAS
Ostalo bom še odkrival _________________ www.MaLiX.si |
Vlado Profesionalec
Objavljeno: Pon Dec 22, 2008 9:25 pm Naslov sporočila: Težave s serijsko komunikacijo in pcf8583 |
Malix,
kot sem ti povedal v ZS, moraš imeti ali original demo ali original Bascom, na žalost tvoj crk ne omogoča upgrade, stare različice programa pa ne podpirajo novih ukazov.
Da bi lahko inštaliral nov demo moraš pobrisati registre.
Vlado |
malix Profesionalec
Objavljeno: Pon Dec 22, 2008 10:35 pm Naslov sporočila: |
Hvala naložil sem 1.11.9.0
$swstack = 64
$framesize = 64
print "Dober dan!"
wait 1 |
Pzpiše mi sledeče
ő*Dober dan!
ő*Dober dan!
Ali je to OK
Tvoj program mi javi napako tukaj
Reg14 = J : Push R14 _________________ www.MaLiX.si |
malix Profesionalec
Objavljeno: Pon Dec 22, 2008 10:50 pm Naslov sporočila: |
Zanima me ali more biti SCL in SDA na pinu PC0 in PC1 "tako kot je označeno v priročniku za ATMEGA32 - sli ji lahko prestaviš tudi drugam in to nastaviš s sledečim ukazom
Config Scl = Portd.5 _________________ www.MaLiX.si |
Objavljeno: Pon Dec 22, 2008 10:57 pm Naslov sporočila: Hm |
Prvo:
Ali si $hwstack in ostale dal takoj na začetek izza $regfile ukaza?
Če si, potem je nekaj narobe ali z nastavitvami tvojega prevajalnika ali z prevajalnikom samim.
Drugo:
Reg14 mora biti definiran v glavnem programu.
Osebno vedno uporabljam nekaj delovnih spremenljivk, ki izgledajo tako in morajo biti definirane v glavnem programu:
Koda: | Dim Reg14 As Iram Byte At 14 Overlay 'register 14
Dim I As Byte 'splošne delovne spremenljivke
Dim J As Byte
Dim K As Byte
Dim L As Byte
Dim M As Byte
Tretje, scl in sda mislim, da so lahko katerikoli portpini. Zdi se mi, da morajo biti tisti, ki so definirani v datasheetu le takrat, kadar želimo, da bo naš procesor i2c slave, kar običajno ni. _________________ Sliši se paradoksalno, a je vendarle res:
Objavljeno: Pon Dec 22, 2008 11:26 pm Naslov sporočila: Probaj tako: |
Progbaj tako:
Koda: | $regfile = "m128def.dat" oziroma tvoj procesor
$lib "mcsbyte.lbx"
$crystal = 8000000
$baud = 38400
$hwstack = 128
$swstack = 64
$framesize = 64
'declare used subs
'Declare variables
Dim S As Byte
Dim M As Byte
Dim H As Byte
Dim D As Byte
Dim Month As Byte
malix Profesionalec
Objavljeno: Tor Dec 23, 2008 12:53 pm Naslov sporočila: |
S tem programom mi je končno uspelo usposobiti PCF8583
Koda: | $regfile = "m32def.dat"
$lib "mcsbyte.lbx"
$crystal = 8000000
$baud = 38400
Dim S As Byte
Dim M As Byte
Dim H As Byte
Dim D As Byte
Dim Month As Byte
Config Sda = Portc.2
Config Scl = Portc.3
Wait 1
Print "ok"
'I2cinit
Do
Call Gettime
Wait 1
Loop
End
Sub Gettime()
End Sub
For I = 1 To 5
I2cwbyte Tm(i)
Next 'write seconds
I2cstop
End Sub |
Žal mi tvoj program še vedno ne deluje.
Javlja polno napak
Koda: | Dancas = Left(niz1 , 14)
Dancas = Dancas + " " |
Tukaj se zagotovo zalomi.
Bi se lahko priporočal za komplet
Zanima me še nekaj.
Ali lahko v enem projektu uporabljam PFC8583 ki ima I2C komunikacijo na pinih Pc3 in Pc4 ter DS1820, ki komunicira preko 1Wire na PC0. _________________ www.MaLiX.si |
Objavljeno: Tor Dec 23, 2008 4:14 pm Naslov sporočila: Tista |
Tista dva ukaza, ki dajeta napako, enostavno izvrzi. Izhajata iz ene izboljšave podprograma, ki je ne potrebuješ.
Kje boš na mikroprocesorju imel scl, sda in 1wire je popolnoma v tvojih rokah _________________ Sliši se paradoksalno, a je vendarle res:
Objavljeno: Tor Dec 23, 2008 7:34 pm Naslov sporočila: |
Oj,
Bascom-AVR podpira RTC s kvarcem 32.768 kHz, poglej si primer megaclock.bas oziroma beri v Help-u Config Clock. PCF-ja sploh ne rabiš
dkone Profesionalec
Pridružen/-a: Sob Dec 2005 17:03 Prispevkov: 176 Kraj: Krško
Objavljeno: Pet Dec 26, 2008 4:16 pm Naslov sporočila: |
Jure je napisal/a: | Oj,
Že že,ampak,če rabiš da ti ura ostane tudi po izklopi napajanja uC-ja,je dobro imeti pcf-ja in dodatno baterijco,ali pa en velik kondezator. _________________ Lp,Denis |
